1981 El Camino Shift Indicator Cable, Column Shift Automatic, For Gauge. I took the dash apart and the cable fell off. I don't know how to put back on.
Any videos or pictures out there that might show something detailing how the cable loops in or around.
Elkybuick
The Clip on the end clips to the Steering Column as you adjust the shift indicator to show what ever gear you are in.
Deputy Director Region 6
First want to say Welcome from Florida !
Here's a pic of where the shift indicator cable should hook up. You may have to fine tune it by moving it up or down on the column
Is the cable off of the steering column or has it completely fallen apart from the selector indicator?
If it is off the column only it is like Elkbuik said, if it has come apart at the indicator you most likely need a need indicator.
Pictures would help.
Mike
