81 - 93 of 93 Posts
Discussion Starter #81
Just another couple of pictures:
Engine Bay:
Recently added a set of painted fuel rail covers from a C4 Vette.
Thinking of doing ceramic coated headers to lower engine compartment temperatures and upgrading the looks too.
Nice picture from last weekend
Wow, what a great looking engine compartment!
I've got A LOT of work to do to get mine even close to looking that good.
Great job Ricardo. Taken it to any shows yet?
Discussion Starter #83
Last upgrade done to Elco:
Replaced my Shoenfeld mild steel headers with an identical set but ceramic coated.
All I can say is: what a difference! The underhood temperatures went down quite a bit and the looks are awesone. When I took the spark plug wires off I found two of them that were severely degraded due to the excess heat being irradiated by the headers. I just cant get over them.
Here is a comparison between the two sets:
Discussion Starter #85
This really is a never ending project. This time I am focusing on the exhaust. I dont like the way the X pipe sounds in comparison to the H pipe, so i decided to modify my PyPES 3" dual exhaust, got rid of the X and replaced it with a fabricated H out of 304 45 deg elbows and T´s .
This is the original PYPES exhaust with the X laying on the floor:
And this is the fabricated H
My next move will be cutting and modifying the straight rear exit pipes in order to convert the system to exit behind the rear wheels.
Good looking work. I have always liked the 5th gens in white.
Just something about the way white and chrome look together.
Discussion Starter #88
Thanks guys, I just can't get enough. Yesterday we modified the rear exit arrangement from the PYPES system and I really like the results. The first two pictures show the original right side pipe and a close up of where we cut the 45 deg bend and 24" of straight pipe off.
These one show the modified right side pipe and its routing.
And finally the end product
Discussion Starter #89
Doing bucket seats
Got a little more carried away into the never ending project. This time I am doing some interior mods. About a year ago I totalled my 1996 F Body due to an accident due to rain coming back from the track. Fortunately there was nobody injured. My F body was in very good shape and I was able to save the complete drivetrain and many interior and body components. The bucket seats are in very good shape and I plan to install them instead of the bench seat.
I will be updating as I make some progress with the swap. Sofar I have removed the bench seat and am installing the bucket seat brackets I got from Mikes Montes.
Discussion Starter #91
Ok, so I got some more done these days. I received my bucket seat brackets from Mikes Montes and proceeded to install them on the floor panels. At first I was considering welding them directly on the floor panels like GM did on the past but after considering it decided going a different way and used Rivnuts and 6mm bolts.
So this is what they look like.
Discussion Starter #92
After reading a few threads regarding FBody seats installed in El Caminos there were several threads stating that the center to center mounting distance was different between F and G bodies, there is a 3/4" difference, being the F Body the narrower one. So I fabricated these 1/4" steel steel adapters which allowed me to move the seats 3/4" inch inwards and used the 1/4" spacers on the other side track to compensate for the added thickness. I first tried mounting the seat without moving it inwards and the door armrest would hit the seat back after closing the door. So I guess this is a must if doing 4th gen F Body seats.
81 - 93 of 93 Posts
