X2Have you changed the fuel filter recently? Or had the injectors cleaned? At that age this is just a question (as I'm not used to that old of a throttle body) could the throttle shaft be worn out and sucking air in because of it? I know if you have that happen with a carb from age you'll get both of those symptoms.
