1 - 3 of 3 Posts
I recently replaced the front 180000 mile springs with the late model hvy s10 springs. Got more rise than I expected. I thought the s10 springs were going to be a lower loaded height? I've been running airlift 1000 on the back for a long time and they seem to do well, but if I replace the air bags this will be the 3rd set? I had replaced the original style air shocks long time ago because they're poor shocks. I put some good shocks on the rear and used the air bags for height adjustment. I don't normally haul much so they were there for height adjustment. Is anyone using something else? After looking it looks like the air bags are the best option??
Frank
Deputy National Director
The airlift 1000 bags have a lifetime warranty, just send email & get new ones, no need to buy new ones
There is many springs out there to choose from, I would search & see what others used
I went with KYB's gas-a-just shocks on all 4
Same happened to me here. I used the MOOG 5660 S10 springs in my ´82. Got a little more height than expected (still a little lower than the El Camino springs MOOG 5608, probably 1/2- 3/4") But ride quality felt much better. S10 springs relaxed length is shorter but wire diameter is a little larger, resulting in higher spring rate.
Airlift 1000 on the back too. Running individual air lines to each bag for loading the passanger side rear corner at the strip.
1 - 3 of 3 Posts
