There is a 5A cruise fuse in the fuse block. My book says pink w black tracer. Follow the blue wire from switch at the bottom of the column. In my particular cruise I finally found a break in the green wire leading out from the module to the VSS. For some reason it is way too long and is folded back and forth in the loom. Of course I have not removed ECM.
