Hi Gang, I ran across this article from the Monte Carlo website for the wiring of a 3rd brake light. (How to install a 3rd brake light in non-light car)
Lucky for us 86 and 87 gbodys, wiring already exists for that 3rd brake light in the light blue wire (6th pin from the right in the attached photo). The plug is next to the fuse block (C209).
In addition to the 3rd brake light in my rear window, I'd like to add turn signals. Could I be so lucky that the green and yellow wires on the right hand end of that same block are the Right (Grn) and Left (Y) turn signals?
132604
The green and yellow are the rear turn signals.
The White wire (second from left in pic) is the wire you need for the third brake light.
Black is horn relay, Blue is RF turn, Lt blue is LF turn, lt green is key in, Tan is door jamb switch, Purple is power from flasher, Brown is power from hazard flasher, White is from brake light switch,
Yellow Left rear, Green right rear
This for an 84 so I hope it helps
