I discovered recently that my Elky has a 250 tranny. Because I am building a 350 to replace the 305, I want to make sure I have a tranny that will handle the increased horsepower without coming apart.
I am looking to generate only about 300 HP, which is about twice what the Elky had new. I want to have decent highway performance, too. Would a 200-4R be a better choice than a 700-R4? I definitely want the overdrive gear and will be converting from column to floor shift as well.
So I guess my questions are these:
1. Which is the least expensive option?
2. What do I need to look for when I am picking a rebuildable core (bell housing/sunshell, particular ID number, etc)?
3. Which will require the least amount of modification to my existing drivetrain components (driveshaft, rear end, etc.)?
4. Which will give the best performance/mileage combination for daily driver and grocery getter?
I will be using the rebuild parts list, so thoughtfully provided by Tranny Mike (I think?), so that when I do rebuild it, it will last for a while.
I know that I will have to drill/cut into the tunnel and have no qualms about doing so, since I will be replacing the carpet and POR-15'ing the floorpans anyway.
Thanks!
Thanks!
