21 - 40 of 56 Posts
Chris, you're a fart smeller, I mean smart feller. Anyway, where do you get all this knowledge?
71 El Camino SS
Jjackson, that casting number is showing as a 1967 casting. Either a 302, 327 or 350 but the 302 for only the Z28 Camaro and 350 for the non-Z28 Camaro. All were 2-bolt mains. If that is the original engine from your '67 Elk, it is a 327. I will run the ID numbers from the front pad and let you know what I find.
That engine stamp code indicates a 327 4-barrel, 275HP L30 with a Powerglide trans and A.I.R (smog)
Discussion Starter #24
3892657 = '65-'67 327 V8 , congrats you got a 327 V8 . VO2IOEC = EC = 8cyl. , 327 , 275 hp , 10.0-1 comp. heads ,4 barrel carb .
Thanks so much for the info! So what was the differences between the different hp 327s? Was it just a carb or something?
71 El Camino SS
Awesome thanks. What’s AIR?
"Air Injection Reaction". An emissions control (smog) component common on California vehicles. I had it on my '67 Camaro. Tubes that inject air into the exhaust manifolds. Does you '67 Elk still have these tubes in the manifolds?
Discussion Starter #28
I have not seen that, although haven’t been looking for it. But that looks pretty obvious.
71 El Camino SS
Well, the records I found for the "EC" in your front stamp on the engine pad indicate that but, as I'm sure you agree with, records can be wrong. Does your Elk have a Powerglide trans?
Discussion Starter #30
From what I’ve read a powerglide is a 2 speed, and I swear I’ve heard it shift 3, but could be wrong. I just had the car brought down and haven’t driven it much recently until I get new tires. Is there a way to tell by looking at it?
71 El Camino SS
14 pan bolts. Pan number "1" in the first pic...
135678
135679
71 El Camino SS
Going by that page it seems it has a 350
Looks like a TH-350 from the pic. The 350 is a three-speed that has 13 pan bolts. The TH-350 was not introduced until 1969 so it looks as though your '67 has been "upgraded" which correlates to your statement that you hear it shift into 3rd.
Discussion Starter #36
Ah I see, well that’s cool I suppose. How would I go about checking if the engine is original and worth keeping the matching numbers? I guess it’s likely that it is since it’s a 327
71 El Camino SS
Feel free to send me a PM if you'd like. I'm happy to help.
Discussion Starter #38
I don't know if this is breaking any group rules here but feel free to call me if you'd like. I'm gonna get carpal tunnel if we keep typing... (760) 415-6265. I love these old Elks and am very happy to help any way I can. -John
Haha okay thanks! Appreciate all the info
EC means it came with a PG , it could have been changed out by a previous owner . I had a '66 283 in my '69 EC which had been a PG but had a Muncie 4 speed in it when I bought in '78 .
21 - 40 of 56 Posts
