1980SteelBeast
·Guest
So after going through 3 stock starters and almost 2 mini starters,I'm wondering what is going on with my 383 having starter problems. I've shimmed the starters as many ways as I could think of and still I'm getting the same result with them not engaging after a few cranks or a few days.
I've researched Car Craft's website,Googled,and asked around and it seems the flexplate could be the problem.
A 350 is internally balanced while a 400 sbc is externally balanced. With my 383 having a 400 crank,and since most 383's have counterweights on the crank,could this 153 tooth flexplate be the wrong one?
HotRodElco told me that my 383 could be out of balance since the starter engages basically when it wants to.
When I called Summit Racing,they pointed me to the flexplate I'm running now which could very well be a 350 flexplate. HotRodElco also said with it being out of balance,I'm not getting the performance I should out it.
So,before I pull a Lance Armstrong and walk away leaving questions unanswered by getting a hatchback 5.0 Mustang,I'd rather try and dig deeper.(even though being a black Lance Armstrong is very inticing):let_it_all_out:
What should I be looking for and what's the way to solve this since I don't have room to pull the engine?
Also,how can I tell the difference between the 350 and 400 flexplate?
