so. im building up my 383 stroker. got heads, intake, carb, some other goodies.
i went to look at cranks and internals, and i found out,
if i use an original 400 crank, then i have to have the block bored and machined to take new stroke and some other things.
but if i buy a "new" 383 crank, does the block still need to have the machine work done? or is it compatible with my 350 block, while giving the 3.750 stroke still?
thanks, any advice will help.:You_Rock:
