1 - 10 of 10 Posts
thinking of putting a 85 350 tpi in my 72
heres the questions
fuel pump used? pusher pump, puller pump ,lift pump, in-tank pump
what or how did you run your fuel supply and return
stock tank with sending unit for fuel gauge ...or is there a late model plastic tank that will fit in the stock location
i searched this site and others as well looks like a lift pump to a pusher pump is the way to go?
also fuel cap vented or non vent?
heres the questions
Mine is not a 3rd gen, it is a 5th gen ('87).
First of all the pump needs to be as close to the tak as possible IF you don't go the in tank route.n
I have done the mid '80's TPI retro fit a few times and this is probably the biggest pain about the process, the fuel pump and lines besides the engine wiring. I have successfully used an external high pressure fuel pump located about 12" from the gas tank and feeding the fuel rail with the orignal 3/8" fuel line and then using the 5/16" vapor line as the return line. When I did my '87 I got "lucky" :banghead: enough to not see the return line had some nice little rust holes on the top of the tank and got the chance to do it again!
I am looking into doing the in-tank fuel pump now, just not sure what is available for the 5th gen's.
The fuel sender unit and dash gauge in mine now are stock, work well.
If I run across anything while looking for an in-tank setup, I'll pass it along.
Bruce
Thanks Bruce
may i ask what pump you used make and part# if you have it
Some have retrofitted late model tanks such as the b-bodywagon caprice/roadmaster, which came with throttle body or multi port pumps, which interchange. I,d go this route for reliabilityof newer factory design & better replacement part availability. There is a thread on tank swap in ls section, it's for 5th gens, but should work for you also. Also many other tpi related posts in that section that I posted in.
Most of us like me that have done efi swaps run the tank vent line high as possible & put an inline fuel filter on the end for venting. I ran f-body lines when I did my first conversion up the drivers side, but any 3/8 & 5/16" steel lines to run the route needed will work, as can fuel injection hose. The factory tpi feed line has the advantage of the factory fuel filter.
Thanks Bruce
Don't remember the exact make/model I have, but it is very close to this one on eBay:
http://www.ebay.com/itm/MSD-High-Pressure-Fuel-Pump-Electric-Fuel-Pump-Roller-Vane-2225-/170872548640?hash=item27c8cc2d20&item=170872548640&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Most important part is that it creates at least 60-70 PSI and then try to match up the size of the input/output to the line you will install it in (i.e. 3/8" is usual/standard for a feed line).
Next thing is to get it connected to the fuel pump relay 12v feed from the ECM/wiring harness. I have an aftermarket Howell wiring harness which makes this really easy. I think there are some other wiring harness makers who have the same thing.
jlcustomz did you need to alter the bed of your camino to fit the top of fi tank where the pump goes
thanks for the reply
I used this part from Moroso. Cut a section out of the filler neck and clamped this in its place for the return line. Works great and hasnt leaked a drop in 3 years.
MOROSO - 65385
Great info!!! Thanks guys:beer:
Discussion Starter #10
right on thanks for the info everyone
1 - 10 of 10 Posts
