So my s10 fuel sender did not work out . the fuel gauge would not even come close to reading . so I broke down and bought the Dixie 4.3 sender .
Now question is what type of fitting connects to that strange 3/8 fuel line ?
worse case i guess i could cut and double flare it . but i would rather get an adapter and connect either with an-6 socketless or Barb .
thanks
I go to a business that does hydraulic hoses and they have the fittings for it that adapt to barb or 6AN. I have them cut the ends off the vent and return and swap them so the 5/16 is then on the return tube and the vent is 1/4".
I hope you have a 17 gallon tank. Doesn't work well in a 22.
This is what I did for the fittings. Pressure line is 4AN and I got that stuff from Summit:
