How Do I Disconnect my 86 el camino intank fuel pump without removing the intank pump.????
I want to use a manual fuel pump on my new 350ci engine.
:yell::yell:unplug the fuel pump relay.the pump will however stop fuel from being sucked by your engine mounted pump.you need to remove the intank pump or use it with a pressure regulator. sorry man
In the link below is circled is that the relay you are talking about:yell::yell:
Pull the relay as ccc has suggested
In the below Link the circled item is it the Fuel Pump Relayunplug the fuel pump relay.the pump will however stop fuel from being sucked by your engine mounted pump.you need to remove the intank pump or use it with a pressure regulator. sorry man
