1 - 10 of 10 Posts
I have a fifth generation with a 1972 454 in it with a turbo 400. I'm thinking about upgrading the engine with a edelbrock top end kit # 2095. It comes with the aluminum heads and intake and a flat tappet cam, with lifters and hardware. It does not come with push rods and rockers? My question is do I go with new stock push rods and rockers or do I need something else. There isn't enough room for roller rockers. And what else will I need?
Why do you say there is no room for roller rockers? I assume you mean that you have short valve covers? I run comp cams steel roller rockers under my short valve covers, never had an issue
use good heat treated pushrods and as stated above small bodied roller rockers.they will help your valve guides live a lot longer and free up a little hp, the heat treated push rods will help keep down harmonics the stock push rods are prone to in hp aplications
Discussion Starter · #4 ·
I didn't think they would fit under the short valve covers, thanks for the info......
If I were spending that kind of bucks, I'd also go with a roller cam and not have to worry about breaking in a new flat tappet cam and chasing down some oil additive or oil with zinc still in it.....Kill two birds with one stone....Dan
the roller cam gives you a lot more free hp and as old coot said saves the cam.i have seen guys flatten a new cam within the first 5 min of running on a big block.i always use soft springs to break in a big block cam then switch to the good ones.
At the $2600 price of the kit, I think I'd choose different pieces. First, I would not no longer use a flat tappet cam. The roller hydraulics give more power with the same advertised duration because the ramps are faster. You'll see more gain per dollar from a decent cam swap than you will with the head swap. If you want to change the heads, I'd go with the Brodix Race Rites instead of the e-brock pieces. I ran the e-brock heads for a while and changed over to the Brodix and I am not going back. Stuff a roller hydraulic cam that is about 225/235 at .050 and .560 lift in there along with a set of the Comp Cams beehive springs and it will wake things up! A set of roller rockers will help save your valve guides. If you are on a budget, do the cam and roller rockers first and then decide if you want to spend the money to swap the heads. Otherwise, Race Rites, the cam and a dual plane manifold like the Edelbrock Performer and you'll be melting the tires in no time.
Discussion Starter · #9 · (Edited)
brodix raceright
I went online and looked at the big block heads, but I'm not sure which ones I would need. All of you have convinced me to stay away from the edelbrock kit. I went on line and there is a dealer on ebay that suggested brodix race right with 294cc intake runners with 119cc chambers. His price was $1574.00 plus shipping. The heads are fully assembled.
Discussion Starter · #10 ·
Okay, I ordered the bordix heads this afternoon, I received the roller rockers in the mail yesterday, Now I have to order a roller hydraulic cam and intake and timing gear.....
1 - 10 of 10 Posts
