Does anyone have a 4L80e behind a carbs motor?
I am using an optishift controller and am having a serious bog down issue in reverse. Idle can be set to anything from 600-1200 and when put in reverse it bogs down to 450-500rpm and slowly dies.
Drive does the same if the idle is set around 700 but is completely fine at 1100.
Any idea? To much trans line pressure maybe?
