1 - 2 of 2 Posts
So, I got a hold of a full SS instrument cluster out of a `73 Chevelle. I removed the old, sweep style. I thought I was in business until I tried putting it in there, and NOPE! Won't fit. :(
Anyone done this before? I'm very tempted just to take a Dremel and cut the room out. The only other option seems to find a dash that had SS style gauges.
make a template from the new cluster and trim the old dash. if you screw it up you needed a different dash anyway to use the cluster you wanted . you will need different senders and the stuff to make the tach work.if it has one
1 - 2 of 2 Posts
