1 - 2 of 2 Posts
hi!... someone have pics of the installation process of the 4th gen ws?
in my 77 the w.s was glued on... and some ******* even glued the trim , so i remove it, saving some of the trim clips (have some more of a donnor car) but now i want to make it right.
any advice on how to do it?
thanks
jk
napa sells the window seal kit.its like a big ribon seal that uses a brush on primer to go on the frame first then the seal,then you primer the glass as well.you overlap the seal at the botom center and use urathane window sealer to seal the ends, make sure the lower cushions are in place to keep the glass from moveing while it cures. get help to keep from breaking it. some people use just the sealer to mount the glass .doing that sometimes lets the glass settle too far down and you end up with the glass too far from the moulding
1 - 2 of 2 Posts
