1 - 11 of 11 Posts
There have been discussions, for years, about the lack of after-market fuel injection fuel tanks for 5th Gen El Caminos. The most common solution has been the adaptation of used Chev Caprice Wagon or Buick Roadmaster Wagon tanks. A couple of months ago, I saw a Facebook post about 1971-72 Chevy El Camino EFI Fuel Tank with Notched Corners, from Tanks Inc.. A subsequent conversation with forum member B52Bombadier (Rick) lead me to believe that tank could possible fit a 5th Gen. It does....It's a perfect fit except that the filler tube exits the Tanks Inc. tank about 1.5" farther to the rear than the stock tank - meaning it doesn't exactly line up with the fuel door. I solved that by cutting off and using the curved filler tube from the stock tank and a angled rubber adapter tube to make a "S" curve that corrected the alignment. Here are some pictures and a parts breakdown.
Tanks Inc.
Tank TM34KN-T $305
Pump GPA-2 $210
Sender (Universal tube type) 6" depth T-GML-06 $98
8" Rubber filler tube adapter (angled) 53C $11
Les, This is a fine thread to help other 5th Gen folks.
Is the new tank size (capacity) similar and the tank baffled?
The new tank is baffled. I'm not sure about the capacity yet. I'm pretty sure my old tank was 22 gal and, I suspect the new tank is probably 17. The old tank was close to an even depth but, the new one is tapered - so, in sure it will hold less. I put in exactly 5 gallons so that when I go fill it up - probably tomorrow - I can determine what the actual capacity is. One of the drivers for getting the new set-up, in addition to getting an in-tank pump, was get the vertical tube type sending unit. The old sending unit finally died but, I always hated that the gauge always stayed on full for about 100 miles and then dropped like a rock.
Hello,
It is precisely a 20 gallon tank, measured upon its first fill up when I installed it.
Yes, I can heartily recommend the installation of the "armless" sending unit for purposes of operating dependability over the alternative. But the armless sender is certainly not fabulous on accuracy until it gets down to a quarter of a tank remaining. At that point, it is perfectly accurate.
Hello,
Thanks Rick. Yeah, as much as I hated the old sending unit, I'm afraid the new one will have similar problems because the tank is tapered and as it gets closer to the bottom (narrower) the depth of fuel will drop faster. I put exactly 5 gallons in initially and the gauge reads just a little over 1/4 full.
Good deal! Looks great Les! Did you use original hangar straps or ones to fit a 71-72? Or are they the same? One other question, the rubber filler adapter, did you have to make a bracket at the door opening or does it ride OK without bouncing around and hitting the frame? My original neck just sits in the hole but is solid metal as you know. I kind of want to up-grade since my original tank was baffled and works good, but, for some reason my Z28 fuel pump on a 4.3FI hanger vibrates the floor of the tank and is quite annoying at times making a loud howling kind of noise. And the fuel gauge is as described, full forever then drops like a rock!
Thanks Joe,
I used the 71-72 hanger straps that came with the tank. They're a little different from the originals but, close enough that, I think, either would have worked. I didn't install a bracket/brace for the filler tube - yet - but I probably will. The filler tube sits perfectly in the door opening but, the weight of the fuel nozzle will probably cause the rubber adapter to flex. I'm thinking that, over time, the constant flexing, at fill-up, may cause the rubber to distort or be damaged. The new pump is much quieter than the in-line pump I was using. I think the "long on full and drop like a rock" is just a symptom of the swing arm/float design. Due to the front-to-back taper in the new tank, I'm afraid the new "armless" sender may still have some tendency for the gauge to drop faster as it gets closer to empty. I'll have to wait and see but, Rick could probably speak to that, since his has been in operation for a while. The whole set-up was a bit more expensive than I had in mind when I first thought about it but, over-all, I'm happy with the results.
Thanks Joe,
Thanks Les, I'm gonna tuck this up-grade in my back pocket for when I get back to the ElCo. Other than the occasional howling from the tank everything works good and driving anywhere is pretty much problem free. Right now I'm about to stuff an LQ9 into an 86 Mustang convertible. Once I get it to the level of my ElCo I'll start whittling away at the various things that annoy me about it like the tank humming!
On a side note, while making room in my garage (for the Mustang) I sold my old 440 Mopar motor and trans to the neighbor that bought Ken's Satellite project! The best part was seeing Ken and telling him we miss him here, keeping distance of course!
Yes, this armless sending unit is accurate at a quarter of a tank but yep, you had better start looking for a gas pump at that point. The drop after that happens quickly.
I bought a baffled 17 gallon FI tank from Carid and ordered the 4.3 FI pump and sending unit from Dixie
Do you have a part number for that tank? I don't have a baffled tank and have to keep over 1/4 all the time. I have starved the pump a couple times cornering. And I like to corner hard ;) Thanks
JC
1 - 11 of 11 Posts
