1 - 20 of 24 Posts
My 1985 el caminos horn button has some cracks in it and I am about to buy a replacement a.s.a.p. I was wanting to know how to remove it and how to put the new one on all info is appreciated.
no you dont have to take off the steering wheel. if you feel befind the steeringwheel on the back side of where youd press the horn there is 1 screw on each side and i beleive its like a 7mm screw head. just put a socket on it and take it out. its very simple to do. mine always loosen up on there own from my system
Before you remove the 2 screws,you should disconnect the battery or pull the fuse so the horn does't go off.After you get the screws out there is a small wire to disconect Just reverse the process to install.
I'm sorry it seems there has been some miscommunication cause I used the wrong term. I am just wanting to remove the horn button/horn emblem from the horn pad as it is cracked and I want to replace it. The thing in the middle that has the bow tie in it sorry for the confusion.
ohh okay i see what you mean now. im not %100 sure about that one. you can still remove it if you undo the screws i mentioned befor and it comes out with it but to replace that you have to but a new cover peice including the sides since its all 1 peice
Discussion Starter #9
oh ok see I didnt know that cause they are just selling that 1 part on ebay guess i better forget about it then lol thank you though :You_Rock:
You can just change out the horn center emblem. As mentioned unhook the battery then take off the "padded" horn bar via the two screws from behind. I find it alot easier to then "peel" the padded portion from the metal inner structure. You can then peel out the center emblem. Install is the reverse.
Hope that makes some sense.
No no glue involved. We had a power outage here tonight or I could have seen this sooner and posted up some pics. I can do that after work tomorrow.
what wheel do you have?? the stock El Camino one or has someone changed it out?
Sounds kinda like you are looking at a SS monte wheel.......
Discussion Starter #16
No I haven't figured it out yet because I can't find one for sale that isn't cracked... Also I believe its the stock wheel.
Kevin, I have 16 store on e-bay that sale some form of El Camino / Caballero parts.
78-88 Monte Carlo Malibu El Camino OR montecarloparts (Same E-bay stores) Out of PA, I saw a black center piece for $32.00
rareelco10 He has a large E-bay store out of Riverside, CA and I only saw the complete steering wheels running from $49.99 to $79.99.
I wish I knew how to send pictures, etc but I don't. I 'm sure I spent over $1,500.00 with Robert from Riverside, Ca and Yes the guy in Pa got a few $$ from me also. Hope this helps. If not I'm retired so I'll look some more if you want. Michael in Virginia:smileyb::smileyb:
Kevin...is this the type of horn center you have? They could be had in a few different colors or trim if you will...
This is the what I call the horn bar and below the center emblem..
The black was used from 78-81 I believe..
Here are some of the other horn center emblems I have here...
I may even have a few others around here somewhere..
Discussion Starter #19
Well I would proably buy that one with the red it in from ya if i didnt just spend all my money on other interior and stereo stuff :neutral: ha
LOL...always money going somewhere...what trim do you have on the dash face and the RH side above the glove box..I just had a quick look on the shelf here and I have a wood grain one with red around the gold center.
Kevin
1 - 20 of 24 Posts
