All parts are for a 5th gen G body:
I don’t get on here much anymore, email me directly at [email protected] if you’d like to purchase or have questions. All prices are negotiable when buying multiple items. I will delete parts when sold. I will add new parts as I find them in the garage.
Used, Steering Column for manual transmission, not tilt - $115 plus shipping
Electric window kit, bezels looks like GM, new - $150 shipped
UMI Lower Tubular Non-adjustable Lower Control Arms, red, part number 3015 - $115 shipped SOLD
Steele 70-3534-72 Door weather stripping (these go around the door) - $100 shipped SOLD
Steele 82-0037-68, Roof rail weather stripping (these seal against the window) - $115 shipped
These parts are from NAPA when I closed my store, selling for my cost. The part numbers are NAPA numbers, you can look them up at NAPA.com for more information. Prices are plus shipping unless you buy everything:
Idler Arm, 268-3654, $20
Tie Rod End Inner, 269-2443 X 2, $20 for the pair
Tie Rod End Outer, 269-2444 X 2, $15 for the pair
Door Striker, 38428, $5
Lamp Relay, AR176, $5
Ball Joint Upper, 260-1091 x 2, $50 for the pair
Back-up Switch Connector, TSC200, $10
Coolant Temperature Sensor, TS4032, $4
Control Arm Bushings, 267-1434 X 2, $20 for 2 sets
Ball Joint Lower, 260-1130, $40 for the pair
Radiator cap, 703-1738, $5
Wheel Cylinder Rear, 37625 X 2, $13 for the pair
AC Resistor Brush, BR25, $8
Ignition Switch w/o Tilt Wheel, KS6622, $15
Motor Mounts, 602-1179 X 2, $20 for the pair
