i have a 79 with a th350 with a 350 could i swp it with a 1964 muncie m20 4 speed? would it be a direct swap? what else would i need beside the trans and the pedals? what kind of clutch would i need?
Keep in mind that the factory rear end wasn't designed to handle the torque from a high horsepower engine. You're going to have to change rear ends if you plan on " jumping " on the power band of a high performance engine.
I had a factory 4-speed, 1981 El Camino that blew out several rear ends when I applied real torque thru the engine. They just blow out. The best part is that they're available in every wrecking yard ( G bodies are out there however, the right gears are hard to find )and you'll become an expert at changing rear ends!! Look for either a Hurst 442 or a Buick Gran National to swap your rear end, otherwise, you too will become an expert in changing rear ends.
The TH350 crossmember will fit, and I'm pretty sure the driveshaft will fit also
