1 - 10 of 10 Posts
I am putting my EC back together slowly but surely. Currently, I am putting the bumper, hitch and taillight harness back together after cleaning and refurbishing.
I believe I read here somewhere that another ECC member had modified the taillight harness so that the outer two lenses have both running lights (brown wire) and brake lights (blue wire).
Does anyone know what/where I can find a pigtail for an 1157 (two filament bulb) for my 85EC and the part number?
This appears to be a pretty straight forward modification in that the new 1157 pigtail wires into the existing black (ground) and brown(running lights) while the blue wire (brake light) is wired from the adjacent pigtail's blue wire?
Let me know if I am missing something here or whether there are other issues that need to be anticipated.
you can get the plugs for under 10 bucks each at any local parts store, orielly's ect..... or the local boneyard.....
you may need to make a new groove in the tailight housing for the dual element socket to plug into the housing i seem to remember that there is a little difference in the groove spacing between the single element and the dual element sockets.............
It appears that 1157 socket is NAPA 787135 (AKA DORMAN 85820) Pigtail Socket Assembly. I will let you know how it fits. Further, I will be installing two LED replacement bulbs for two of the 1157s. The Part Number is BK SGL7443RD (NAPA).
Converted one tail light assembly from two taillights only to tailights and brake/turn signal (I changed from single filament bulbs to dual filament bulbs). When finished, I will have three lamps blinking for turn signals on rear and six lamps lit for brakes. I used 7443 bulb and sockets. I was disappointed by the 7443 LED bulbs purchased as there was no difference between the brightness of the brake lights and tail lights. In order to get necessary clearance, I had to fab up 1/2" spacers for each of the taillights.
In a stock situation the taillights use a 194 bulb which is liekly less than an inch overall in length. A 7443 bulb is longer than a 194 but not as long or wide as an 1157 bulb.
auto zone
to Compare
Price: $10.19
Dorman/Conduct-Tite GM 3-wire twist-lock tail and stop light socket
(0 reviews)
Click to View Details
Part Number: 85821
Dorman/Directional Indicator Bulb Socket
For your 1987 Chevrolet Truck El Camino 5.0L Carburetor OHV 8cyl
Price: $6.19
Enlarge Image
Part Number: 85830
AVAILABILITY:
STORE PICK UP
In Stock
SHIP TO HOME
In Stock
Ships within 1-2 business days.
ADD TO CART
Dorman 85821 socket assembly utilizes an 1157 bulb which is very long and wider in comparison to the 7443 bulb. It seems to me that the 7443 is a better fit than the 1157 bulb and socket (Dorman 82821).
Discussion Starter #8 (Edited)
Here is a pic of 7443 sockets installed into modified tail light lens (note 1/2" white spacer that socket snaps into);
Here is a pic of 7443 LED and incandescent bulbs compared;
Here is a closeup pic of 7443 socket:
Here is a closeup pic of 7443 socket (side view):
Looks like you know what your doing can't wait to see the end result.:beer::beer:
1 - 10 of 10 Posts
