1 - 3 of 3 Posts
Does anyone know if all I need to convert to 2-speed wipers is, 2-speed motor, 2-speed switch and wiper wiring harness for 2-speed? Is this all I need or is there more? I'd hate to purchase and install and still not have 2-speed. All help and any suggestions are appreciated.
Yep
Try to get the set from a 67
The motor is available commercially---Napa might even have it
The switch is available from several sources.
And the wiper harness -- you will want to get one from a 66, as it is a separate harness altogether.
I have not noticed a 2spd '66 wiper switch available, and the 65/66 knob will not fit the
the 67 switch
If you opt to go with the 67 switch with a 66 harness-----you will need in addition to the harness, a harness extension for the 66. you will also need to get a connector body for the harness for a 67 as the 66 has a different pin-out shape than the 67.
If you get this stuff, I can help with the wiring changes
1 - 3 of 3 Posts
