The other day I noticed that I had, what appeared to be oil dripping from the front of my engine. I had just fixed a leaky oil sensor the week before and was finally enjoying a clean driveway and garage floor - so naturally I am not happy. Anyway, when I popped the hood I noticed that the whole front of the motor, belts, pullies, fan etc were covered. I checked the level on the power steering pump and it doesn't even register on the dip stick. I'm thinking that it is actually the steering fluid and that I may need to rebuild the pump. What is the best way to check the pump for leaks? Should I use ATF or PSF? If I run the car like this will I damage anything?
By the way, I didn't lose steering. But I only made a very short run on the last trip.
