1 - 20 of 29 Posts
Since the Camino is closer to "done", my dad {he's also 68} and I are getting the car ready for the LSA/6L90E transplant.
127701
Discussion Starter · #2 · (Edited)
This is the new "heart" that will someday motivate her a 'lil better than the sleepy, numbers matching 327.
127702
@ 87ls5.3 : It's supercharged, I'd say 2018-19 Cadillac CTS V.
Insane power! That's gonna be interesting in that '68.
@kat0069 , '67-69 RS/SS....my all time favorite car. Lovely car.
Start a build thread when you can
Might have to put it on another site for a build thread! However, like I said.......Gonna be fun!
Discussion Starter · #6 · (Edited)
That's gonna be fun! What year did it come out of?
2014 sir, about 80 HP less than a '19, but should still be a beast.
Discussion Starter · #7 ·
This is the engine bay as it sits now, with the 327 and 200 4R from the Camino pulled out. Gonna put an under dash booster on it and clean up the firewall.
127712
I've got a full QA1 set up for the front end, keeping the factory front subframe.
Discussion Starter · #8 ·
This picture is nice, I hope to make mine at least this nice.
127713
Discussion Starter · #9 ·
Well, couple shot of the Camaro. The drivers floor is in GOOD shape, got it cleaned up, wire wheeled and coated with POR 15.
127824
This picture shows how well the larger tunnel for the 6L90E is going to fit up.
127825
This picture also shows that the passengers floor didn't fare NEARLY as well as the drivers. I have purchased a passengers partial pan and plan on replacing it forward of the seat mount plate. There is a small place in the rear foot area that needs a tiny patch as well, but is otherwise solid.
Bought an air nibbler and flange / punch tool. I need to get a 75/25 gas bottle for my welder and get to work I guess!
@kat0069 Wow. Amazing progress. Now I forget what the term is but I’ve seen vids of folks hiding all wires, relays etc. for that clean engine only look. Lots of work no doubt.
Pls post a link to the “other” site if you have a build thread there. I’m active in the Camaro5 forum. I have a ‘14 Camaro SS/RS...sadly, auto with the L99. Keep up the great work!
Discussion Starter · #12 ·
We've got it torn down to this. Crusty bit in pretty good shape over all.
127964
127965
Discussion Starter · #13 ·
My dad went to work with the wire wheel.
127966
And put the POR 15 on it.
127967
Discussion Starter · #14 ·
Now we are getting the new front suspension (QA1 with single adjustable coilovers) and Pro-Forged steering components.
127968
Discussion Starter · #15 ·
Frame is painted and the QA1 is on along with the new steering components. Ready to go to the Rod Shop.
128099
128100
  • Like
Reactions: 87ls5.3
Discussion Starter · #17 ·
New passengers floorboard fit and finished along with the tunnel being trimmed for the 6L90E and new motor mounts for the LSA.
128330
128329
what kind of controller did you find for the 6L90e
Discussion Starter · #19 ·
I got ALL the computers and wiring (along with shifter and pedals) out of the original car, but I'm most likely going with a Holley set up so I can tune individual cylinders and run the transmission.
Discussion Starter · #20 ·
LSA waiting to slide into place so we can fit the new trans tunnel.
128392
While the engine is stripped down, the plan is to install a Texas Speed stage 3 cam and anything else it needs to live in the engine and work with the transmission.
Later on it gets a completely smooth firewall and down tubes from the firewall to the frame horns. Then completely custom inner panels in the engine bay.
1 - 20 of 29 Posts
