1 - 11 of 11 Posts
My 68 wont pass NV smog.. At low idle it's fine, at high idle CO2 is over 11.0 and should be under 4? They are telling me to replace my carburetor, but the car runs fine..? What to do, what to do...ecchhh...:dontknow:
2 bbl? 4 bbl? AFB? Holley? What are you running?
With your symptoms the first thing I would check would be the float level - its easy and its free. If you are rich off idle if the float level is OK then you are heading into main jets/metering rods (depending on what kind of carb).
Discussion Starter · #5 ·
I think its a Rochester quadra jet..having a friend take a look at the float level and he's said somethin about the accelerator pump? I'm lost on carb stuff (till now):???:
accelerator pump only works to add fuel when you move the accelerator linkage. Steady throttle it has no effect.
yep, when ya repair the carb just replace the float. also make sure to replace the float needle and seat.
1 - 11 of 11 Posts
