'68 disc brake upgrade conversion using off the shelf Chevy parts?
Has drums now.
Not going racing, no need for 13", prefer to use original GM parts rather then after-market.
Plan to use 15" wheels.
Hope to add rear disc brakes later.
Not sure which rear axle it has, it is an original 327/auto car.
Local parts house will have everything but the spindles------and those can be modified.
Or you can buy the spindles and caliper brackets from a vendor.
Rotors, calipers, bearings, hoses can all come from an AutoZombie store (or similar)
You will be looking for parts for a 72 Chevelle.
Cool, and for the rear?
I thought the front would be something like that.
I know there is no "Original" application for the rear.
Will the Camaro/Firebird caliper-rotor retrofit kits fit with 15" wheels?
there are a lot of factory stuff to do the rears.camaro/firebird,seville,caprice,s10 blazer
