1 - 3 of 3 Posts
OK so i got the info from the john moderator mechanic on the HEI. THat was what i needed . I do have a question though , what is the identifying look or number of the non comp controlled HEI? I think i have made some mistakes on some other projects with these
A non-computer controlled HEI will have a vacuum pod on the side, much like the standard non-HEI distributor.
A computer controlled (large) HEI will have a short wire cluster that terminates at a multiple pin plug socket. (4 wires)
The small HEI (later model) has the electrial connectors on the side of the distributor, and no vacuum pod.
electronic ign
Thanks for the great info. I will use it . This is great
1 - 3 of 3 Posts
