1 - 9 of 9 Posts
hey guys need some helpthe shift linkage on a turbo 400cant seem to find the correct configuration .it has a floor shift that came with car.Also should this have a modulator valve on rt side,and looks like a fitting on dr side in front of speedo??
ant help is appreciated thanks scott:beer:
Discussion Starter · #4 ·
appears to be a hydralic fitting .i have a bunch of brackets and a plate but not sure how they are installed .this shifter i got with car is about 7-8 in long and about 4 in high .not sure how to connet linkage to shifter? has a hole in floor pan but imo is useless cause the tail stockcovers it up.
thanks for the reply mike:beer:
Discussion Starter · #6 ·
sorry guys trying to figure out how to load pics in my posts.the brakcet i have looks as though it should bolt to frame some how.the part on trans is like a u shape with a hole in center that mounts on trans and has a hole on either side that a rod for linkagethat i think should bolt to transgoes into it
again sorry bout pics;
That is the kick down for passing gear. 12V applied equals downshift.
1 - 9 of 9 Posts
