What does the 700r4 speedo cable connect too ???
What is name of part that is connected uo too.???
I have mechanical speedo so gear housing is my part thanks ^.For mechanical speedo it be called a gear housing there are two kinds, for 34 to 39 tooth driven gears and another for 40 to 45 tooth driven gears
for electronic it's called a speed sensor(gear driven or hall effect/magnetic)
The housing is held on by a small bracket and bolt. The difference between the 2 housings is where the gear shaft hole is centered or offset in the housing to accommodate the different gear diameters. The housing has numbers on it that show what speedo gears it works with.I have mechanical speedo so gear housing is my part thanks ^.
Whats the difference in the two gear housing 34 to 39 and 40 to 45 tooth driven gears ???
How do you install gear housing i put one in trans but it keeps falling out.
My Speedo Housing has numbers 40 to 45 on itThe housing is held on by a small bracket and bolt. The difference between the 2 housings is where the gear shaft hole is centered or offset in the housing to accommodate the different gear diameters. The housing has numbers on it that show what speedo gears it works with.
I'm assuming you have the larger speedo housing. The small bullet shaped housings are all centered the same. :beer:
Can I get the retainer and bolt from a TH-350 transmission????There's a groove in the speedo gear housing in which a keeper, which bolts (10mm) to the trans housing, is inserted. This keeper retains the speedo gear housing in place.
My 700r4 Drive gear is color blue so i assume it is a 18 ToothYou will need to find out what speedo gears (drive & driven) you need to make your speedo read correctly !!
700r4 with a Blue Drive gear and speedo housing 40 to 45 Rearend 2:56 ratio tires are so rally rims 15in Gmthe gears are somewhat specific as to which other gears they will mate to.you need the rear gear and tire info then you can look it up on a speedo gear chart to find the apropriate gear set. i have several gm charts but you need to give more info
My tires are 255/60/15My 700r4 Drive gear is color blue so i assume it is a 18 Tooth
and i dont have a driven gear.
Just ran across this photo. This part (keeper) is sold new at Gbodyparts.comThere's a groove in the speedo gear housing in which a keeper, which bolts (10mm) to the trans housing, is inserted. This keeper retains the speedo gear housing in place.
nice just what i needed and part is universaljust ran across this photo. This part (keeper) is sold new at gbodyparts.com
