Hello,
Has anyone successfully (without mods) fit an Edelbrock Performer RPM (#7101), RPM Air-Gap (#7501) or Performer Air-Gap (#2601) intake manifold on your SBC 350 with an Edelbrock Performer/AVS2 or Holley 4150/4160 carburetor and a standard 14" wide air cleaner (3" tall air filter) under your factory SS hood (no cowl induction)?
Per Edelbrock:
Edelbrock Performer RPM #7101 and RPM Air-Gap #7501 manifold height specs: A-4.20", B-5.25", carb pad height 4.27" (A+B/2)
(.70" taller than original #2101)
Edelbrock Performer Air-Gap #2601 manifold height specs: A-3.72", B-4.92", carb pad height 4.32" (A+B/2)
(.27" taller than original #2101)
I just bought a Jegs dual plane intake #555-513000 (JEGS 513000: Intake Manifold for 1955-1986 Small Block Chevy 262-400, Dual Plane [Natural] - JEGS High Performance) A-4.29", B-5.31", carb pad height 4.80" (A+B/2)
Per Summit Racing, both the Edelbrock Performer/AVS2 and Holley 4150/4160 carburetors are 3.25" tall
(Carburetor Height)
Of course, air cleaner height will be dependent upon base type ("standard" vs "drop-base") but I'm just trying to get a feel for whether or not this is a no-go even with my factory SS hood. I know I could use a long straight edge to do some measurements and calculate clearance but I was hoping this post might yield some "real-life" experiences. Should have sent this post BEFORE I bought the manifold. Duh...
Thank you,
John
Per Edelbrock:
(Carburetor Height)
Thank you,
John
