1972 GMC Sprint, 400c.i. w/aftermarket cam, manifold, carb and headers. LS swap planned for 2023!
Greetings!
I joined the forum not long ago and wanted to start documenting what I'm doing with my '72 Sprint. Long-term goal is to build a fun daily driver that I can also autocross and/or run time trials with. Here is the overview of my starting point and short-term (12-months) goals:
- 400c.i. w/Edelbrock Performer intake manifold, mild cam, Patriot mid-length headers. Goal: swap out for a blown LS with 500-600 rwhp.
- TH400 is in place now...but it fills my drip pan with fluid weekly. Goal: swap out for a built 4L60e.
- Came with 17" Torque Thrust II wheels, bone stock suspension. Goals: modernize with hi-perf, modern suspension, brakes, and larger wheels/hi-perf tires. Lower by 2".
- Exterior is Olive Green, serviceable, and has no mods. Goals: maximize existing paint and trim using elbow grease. ("Go" is more important than "show" in this 1st pass.)
- Interior is black and 100% stock. Goals: add console and floor shifter to floor, put in functional/comfortable bucket seats, replace original A/C w/Vintage Air, replace analog gauges with Dakota Digital gauges, replace/refresh the rest as needed.
- Electrical is stock, but messy. Goal: rewire for safety, upgrade headlights.
I bought the car last October and retired this April, so just now really able to make some progress. (My Durango got relegated to living on the driveway while the Sprint takes up two garage bays, so I'm motivated to get the Sprint on all four wheels again soon.) That said, here is what's been accomplished since October:
- Cleaned up under the hood:
- Replaced air cleaner w/Edelbrock components
- Replaced fuel filter and fuel lines
- Removed valve covers, replaced leaking gaskets and reassembled with new valve covers. (The original valve covers were high-profile and didn't need to be.)
- Replaced driver's side header gasket (exhaust leak)
- Attempted carb rebuild, but a previous owner appeared to have drilled through carb body trying to remove a jet. (That explains the puddle of gas on the intake manifold!) Replaced it with an Edelbrock 600CFM Performer carb and it's running pretty good!
- Removed ALL of the original suspension, brakes, steering components, inner fenders and stock 10-bolt rear
- Front end:
- Installed UMI Performance Upper Control Arms & Lower Control Arms (w/Delrin bushings)
- Installed Viking Warrior 2-Way Adjustable coil-overs w/450# springs
- Installed Baer 14" Pro+ brakes
- Installed new rag joint, Lee Power Steering quick-ratio power steering gearbox (12:1), and Proforged end-to-end steering linkage
- Rear end:
- Installed frame braces
- Attached new UMI Performance upper control arms (with roto-joints), lower trailing arms, and Viking 2-way coil-overs (with 150# springs) in preparation for mounting Moser rear end
- Other
- Replaced original brake hard lines with new
- Replaced original master cylinder with the Baer "ReMaster" unit
- Replaced original brake proportioning valve with new junction for rear brakes and added the Baer adjustable proportioning valve
- Replaced various worn hoses and belts
- Repaired passenger-side door handle latch
- Polished chrome to see what I really had (most of it is in very good condition, but some pieces will get re-chromed or replaced).
- Cleaned up things as I went through the removal/replacement of parts. For instance, the steering shaft got stripped down to bare metal and received a few coats of Clear coat before it was put back in. Same for the stainless power steering lines.
I'm waiting for a few parts, but by the end of this month I hope to:
- Mount the new 12-bolt Moser rear end (also w/Baer 14" Pro+ brakes)
- Measure for wheels/tires and order them
- Measure to see if the drive shaft needs to be shortened or replaced and take action as necessary
- Install new (and massive!) front and rear UMI Performance sway bars
- Nut-and-bolt all of my work to ensure I didn't miss anything
...and before Hot August Nights:
- Mount new rims/tires
- Torque everything to spec while at ride height
- Get a four-wheel alignment (and have pinion angle adjusted to spec)
- Repair transmission leak
- Maintenance: oil and filter change, flush radiator
- Color sand and then buff the entire exterior
- Take a few local test drives
Adding some pics and looking forward to your comments and suggestions!
- Front end:
- Rear end:
- Other
