I wasn't aware that you could get the push in standard signal stalk aftermarket? Do you happen to have a link for that? I thought the only one available was the one that's held in with a screw...used prior to the 78-87 run.I found one for my 86 at Autozone for $10 new.They also have the one with the cruise control wire for $40 new.I installed the first one way back & haven't had any problems with it.I still have the one with the wire I didn't use $20 if anyone wants it PM me.
Yeah in 82 they had incoprated the wiper in the stalk. I have a few of what you're looking for Bobby....standard lever no cruise or wiper.After I think 82? they have the wiper switch on them. Mine is plain push in type. Looks just like the tilt lever but longer.
I didn't buy it on line,I just walked into Autozone & found it hanging from a shelf in the Help section.They had other ones there for other models too.I found some other parts there that I had bought unline & they were dirt cheap.One that I had paid $35 for 2.99.I don't know if the one I bought will fit a 78 but mine just pulls out & pushes in with a twist.You might try autozone.comI wasn't aware that you could get the push in standard signal stalk aftermarket? Do you happen to have a link for that? I thought the only one available was the one that's held in with a screw...used prior to the 78-87 run.
Bobby you might want to check into this one for $10.
I guess that's entirely possible...we don't have Autozone up here and can't say I've ever really looked in the Help section our Auto parts stores have here.I didn't buy it on line,I just walked into Autozone & found it hanging from a shelf in the Help section.They had other ones there for other models too.I found some other parts there that I had bought unline & they were dirt cheap.One that I had paid $35 for 2.99.I don't know if the one I bought will fit a 78 but mine just pulls out & pushes in with a twist.You might try autozone.com
OK neither one of those. Mine has the knob of the plain one but is a push-in arm like the 82 & up.
