Does anyone know if the impact strip bumpers originally on 79 el Camino can be replaced with bumpers that do not have the impact strip?
And if so, any issues with mounting hardware?
Thanks guys and gals
Hi Craneguy, welcome from Idaho. Glad you've joined us. OPGI carries new bumpers for 79, without needing an impact strip. You can check them out to see if it will work for you. Have fun and enjoy your 79.
hello Idaho
I’m in Tennessee now but originally from Rathdrum, ID. Yes, I found the bumpers but am curious wether or not the bumpers without impact strip will bolt right up to my 79 which came with the impact strip?
Thanks so much
Yes, found bumpers but wondering if the non impact strip bumpers are the same as impact strip bumpers as far as mounting?
Thank you Elk
The bumpers are the same. You could go new or used.
X2, The chrome front and rear bar will bolt up to the original brackets and energy absorbers. The only difference is extra holes for the impact strips.
