The problem that I have is the starter wire isn't hooked up so when I turn the key it doesn't start but if I put Power to that starter wire that's hanging out it starts I don't know where the starter wire goes so I can turn the key for the car to start
A Purple wire? That'll go under the steering column coming from the key ignition switch. Power goes upto the switch, comes back down the purple wire which is only powered when the key is turned to start. Look for a terminal block or plug where the purple from the key stops.
