I have an 87 Caballero, and found a solid 83 Malibu front end. Will all these parts bolt up the same, or are there differences? Also, it had a 6 cylinder, mine is a 305, will that be an issue? (different radiator, etc?) Thanks guys.
The grill and headlight bezels and such probably wouldn't bolt to your current nose, but if your swapping the entire nose its a bolt on. The only thing that would be different is the radiator and fan shroud. But the small block radiator will bolt into the V6 nose
radiator ,shroud and ac condenser are engine specific.rad is smaller,shroud is longer and ac condenser has the lines on the oposite side.v8 on driver side v6 on pass side.sheet metal is all the same as long as the 83 had the correct front end in the first place (4 headlights)
