B
blake22
·Guest
when i turn the wipers on all that happens is i can hear a quiet little click coming from around the wiper motor area. it sounds like a relay but im not sure. there is two plug ins on the motor. one has 4 wires and one as 2. the one with 4 wires must be the speeds because as i switch it between hi med and low speed one is hot while the other 2 arent. then the fourth wire in this connection is a red one. i would assume this is supposed to be hot?? it has no power at any time. what is this wire and why wouldnt it have power? the wire from the fuze box is only like 8 in long so i can see that there is nothing wrong with it
