I have an 84 el camino. I am puttin new bushings in the upper control arm. The shaft has a washer on it that goes inboard of the bushings. I can't remember if the washer goes on the forward or aft end of the shaft. Any help is much appreciated.
I see what you mean, I have never noticed them before..
if I was guessing id say put it in the front?? but I don't know for sure..
do you see any wear marks on the shaft? one should be slightly longer..
can you tell front the from the rear?
did a some searchin, no help
noticed the 2002 S10 has washers inside both bushings..
:texas:
Thanks for the reply. I took a guess and put the washer on the aft end. Hope I am right. :dontknow:
