1 - 3 of 3 Posts
Does anyone know whether the 1985 EC V8 (with gauges and tach) engine wiring harness is still available? If so, where can I find it.
Afre you converting to gauges? If so, I don't think there is any real difference between a tach and gauge harness and a warning light harness. The tach lead runs separately through the firewall and sending units need to replace the oil pressure and temp switches on the engine block. The wiring is the same up to the instrument cluster, but the gauge cluster and the idiot light cluster take a different printed circuit.
any of the major wiring kit suppliers can supply a stock harness. Check the street rod mags
:poke:
1 - 3 of 3 Posts
