1 - 11 of 11 Posts
hey does this car have a computer ?
And does this car have the 4 speed auto,and is it comp controlled ?I see a vacuume line comming off the back.
Yes, located near the right front kick panel under the dash.
Probably a 3 speed. You can tell by the shift indicator. Should have a DRIVE and selects for the lower gears. Only 2 lows? Trans is controlled by the vacuum line to the modulator and the downshift cable. May contain a lock up convertor but I don't know what trans they put in there.
Trans needs that line to shift.
It certainly came with one from the factory. Check in the passenger side kick panel to see if it's still there.
Look at the gear shift indicator. If it looks like this:
then you have a 3 speed automatic. If it looks like this:
then you have a four speed automatic with overdrive. The only thing in the tranny that is controlled by the computer is the torque convertor lockup.
:mrgreen:
Not only does the lockup torque converter depend on the computer, but a throttle position indicator in the carburetor must also be functioning correctly. They work hand-in-hand to control when the torque converter locks up.
85 camino
MAN thanks for the quic response! I like this alot . So i guess the big wire harness comming from the rt side fire wall that has been cut off is for the computer,,,,,,,,,I guess thats the end of that. The car runs , but from what you say the trans may have a lock up controlled by the comp and throttle . I havent driven it exept for to drive it up the car trailor so i dont know. Is there a kit that by passes the comp controlls?I may have to part the thing out and use the eng and trans for another camino
Re: 85 camino
exair said:
... from what you say the trans may have a lock up controlled by the comp... Is there a kit that by passes the comp controlls?
First, take a look under your Elky to decide what you have. Here is a link to ID the transmission pan. The 200-4R was an optional transmission in 85 and you may have a different one.
Second, if it is a 200-4R it's not difficult to get the TCC lockup working without a computer. TCI makes a universal kit to adapt the TCC in a 700-R4 or a 200-4R to a non-computer controlled car. Universal TCC Lock-Up Kit
85 camino
Thank you very much , I am learning alot here. I'll report back as soon as i find out what to do
"Not only does the lockup torque converter depend on the computer, but a throttle position indicator in the carburetor must also be functioning correctly."
Thanks spoonplugger, that explains why the torque converter doesn't lock up after I replaced the computer carb with a Holley.
Discussion Starter #9
85 camino
man this can get deep. i think this page can save me alot of lost time and money
Discussion Starter #11
85 camino
YEs sir i took the info and inspected the car. Its a 3 spd ,the comp harness is cut out . I started it again and it runds soo bad . I think its a flat cam or timing chain . I may have to part this one out . Did any one ans my 68 elcamino eng wireing harness questions
1 - 11 of 11 Posts
