Hi All,
Getting going on my 86 Caballero. The engine runs fine (video) and it drives well, however, it looks like the previous owner was starting to remove the computer controls. A standard GM HEI is now installed and there are some loose harness plugs under hood. I'm pretty good with a wiring diagram, but I thought I would ask the "brain trust" here to ID the plugs in one of the photos. The mixture solenoid on the carb and its harness are connected and appear to be untampered, but there is no power (solenoid ticking) so its running full rich.
Anyway, if anyone can comment on what these plugs are, it would be a much appreciated head start for me before I start going through the shop manual. Here is a link of the replacement distributor I bought More Information for CARDONE 841875 and I'm pretty sure the white connector (center in picture) goes to that, and the 4-wire connector with the green gasket (right) I'm not sure, and the tan one (left) don't know either. I've looked around for "female" connectors on a harness but none to be found.
Thanks, Paul
Thanks, Paul
