Ok my 86 el camino driver door will not shut I got the door to shut ONCE when i used screwdriver and turned the hook thing in the door that catches the striker
I Dont know i turned it a few times with a screwdriver and the door shut then open and would not shut again but A doorROD is also removed but i dont know how to put it back in the door.OK so then what? Does it fall back into the locked position after you open the door? Take it out and check for a broken spring.
