Ok and get the primer mentioned by Fixitman1 in the first thread. It comes in a can with a brush mounted to the cap. take a gasket scraper and get all the old material out of there. If you scratch the paint you can either use some black spray paint or just the brush on primer. The primer alone is fine. Then install all your clips. From here just pick up from the other thread. Trial fit the glass, mark with tape, install ribbon on glass, install, then sealer, then moldings. Again try to keep it dry for 24 hours if you can. A light rain won't really hurt but if it can be avoided all the better.
