the wiring diagrams listed on the website don't jive with my truck.??? How do you read this printed circuit connection diagrams/? Which is top row and which is bottom row?? Mine is numbered on plug, isn't there a diagram with the numbers corresponding?
I'm trying to verify my ground so I can run a new one to a good source to make sure my gages are getting proper ground, at present, no gages work, all lights work?????
I assume the black is the ground but it is like the second wire from the right on the plug but the 6th from the left on the diagram???
HELP?///
The black is the ground. The drawing is just that and done to the convenience of the draftsman.
Gages
You also need 12VDC to the gages. Check fuse 11 MARKED GAGES. The 12VDC to the printed circuit for the gages goes thru the 3rd connection from the TOP left looking from the drivers seat.
thank you all for the help, I have some things to check out now....thanks
