1 - 9 of 9 Posts
So I have an 87 el Camino v6 from my understanding it’s all stock. Need help clarifying what that electrical plug is and how to replace it. It’s very loose when I move it I can see trans fluid leaking thanks in advance
127468
welcome Rj
if that is a original, the thru the case connector ??
there is a O-ring seal around the connector internally,
youll have to drop the pan to replace it..
the oring and connector are on some of the trans websites too..
Pic link
heres a pic search
Ok cool thanks, how do I go about checking what transmission I have just to be sure I get the right part
Compare the transmission pan and the number of bolts
Holding it on. Google Chevrolet transmission pans or do a search on this site.
By that cut off corner on the pan, it looks to be a thm350.
Ok cool here is the best picture I have saved, will have to get under there for a better look at the bolts
127480
1 - 9 of 9 Posts
