I have an 88 TPI 350 with a 700R4 transmission. The engine has a cold start injector. Is there an advantage to not using the cold start injector and blocking off the port or will it be needed? If I block it off will I need to have a chip programmed to exclude it? Its going to be in my 83 El Camino. Thanks.
