1 - 13 of 13 Posts
1974 el camino Chevrolet 2 carb 400
after getting my el camino i decided to start stripping the interior but i needed to get the old seat/bench out. I got one of the 4 bolts holding the bench in place but the other 3 are rusted in or just destroyed, any tips on how to get them out or just breakem?
140759
140760
140761
Plenty of Spray Foam Deep-Creep - spray on both top and bottom of the bolts. Allow a day or two for it to penetrate. Heat from a torch may help too.
If it becomes necessary to cut the bolt head off, be careful to leave enough to grab with pliers/vice-grip OR ??
1984 Conquista
1) well, maybe some PB blaster to soak'em down if you wanted to keep the fasteners and not damage anything else
2) using a 4 or 4 1/2" cutting wheel on a grinder cut the heads off of them either in the cabin or underside of the unibody, of course you will probably damage the seat brackets
3) if no grinder then try maybe a hacksaw or air chisel
1984 Conquista
:LOL: Rick.... u were furst
Discussion Starter · #5 ·
Honestly i was thinking about using a E saw and cut the brackets off then drilling the first bolt only because the bracket looks really bad and needs replaced then itll be easier to get the bolts and the carpet out
Even an inexpensive Harbor Freight electric cutoff wheel would melt through those rusty seat bracket bolts. I had to do the same with three out of four of my seat bolts.
Discussion Starter · #7 ·
Motor vehicle Automotive tire Hood Sky Bumper
bolts seats and carpet is out the floor is not in the best but for how long it sat it looks really good took a can of liquid wrench but i got them out thank yall for the great ideas if that didn’t work out
Drill out the bolt with a progressively larger bit until you can use a punch or small chisel to roll out the shell of the bolt thats left. Rechase the threads with a tap and you're good to go.
Wayne I'm confused. o_O
OP says he got the bolts out. Does he still have to drill out the holes?
Dave
Discussion Starter · #11 ·
Good to know also if the floor board is bad all the way to the bolts would i still have to rethread them for when i get new floor panels or will they be pre tapped
1 - 13 of 13 Posts
