Since it got hot here in So Cal (100+ degrees) my new 355 in my 84 has been running a little warm. 195 on the highway w/o AC, 200 with AC and 210-215 in stop and go with AC on. Radiator is a new Murray #433612.
I was going to swap my thermostat for a 160 but was advised not to by a mechanic not to. He thought maybe my current thermostat was defective. He advised me to put in a new 195 and I did that today. He was thinking that the coolant was traveling too fast thru the rad to cool off much.So with a new 195 thermostat today it was 100 degrees outside and she is now running 200-210 with or without the AC at all speeds. The clutch fan kicks in at 210 and cools it back down to 205. So i guess he may have been partially correct as it is now not spiking up to 215.
Should I actually try a 160 thermostat? Put an electric push fan in front of the rad? Try a high capacity radiator? Just leave it alone as it does not boil over. What would you guys do?
Thanks,
RTT
Thanks,
RTT
