My 80 was a standard floor shift from the factory. It has a little lever beside where the ignition is that you push down to remove keys (still don't know what that’s about?)
But the problem is the key will not return to locked position to remove keys or turn forward enough to start. It will go to run but not start? It seems like something has slid forward not allowing the key to turn all the way. I did a search and I see and adjustment on the switch but I don't see the key pushing the rod in the column?
Anyone had this problem?:dontknow:
