1 - 12 of 12 Posts
1979 BASE 305 AUTO/FACTORY AIR.. HELP.. I AM REPLACING A/C COMPRESSOR WITH REBUILT..IT IS FACTORY A6=BIG UGLY THING..ORIGINAL HAS A ELECTRIC PLUG ON THE REAR PRONG TYPE THING..REPLACEMENT DOES NOT HAVE IT,,BUT A CAP IN SAME PLACE HELD IN WI:D(y)TH A SNAP RING.. THE PRONG THING DOES NOT WANT TO COME OUT OF OLD ONE..IS IT JUST AN EXTRA GROUND OR DOES IT DO ANYTHING??THANKS IN ADVANCE FOR ANY HELP/INFO.. I HAVE TO TYPE IN CAPS AS I AM HARD OF HEARING..
El Camino Central Founder/Co-Founder N.E.C.O.A.
If you cannot get the old switch out, replace with new in the new compressor. It is a High Pressure cutout switch, it's primary purpose is to save the compressor, hoses and system in the event of an over charge, retriction or an air flow issue. Do not just ground the wire as you are defeating the purpose of the protection it provides. Ever have a a dischrge hose blow on you while under the hood?
I have, it isn't fun.
1 - 12 of 12 Posts
